OP25 config help (boatbod branch)
studysession
Carroll County, MD
Hi -
I feel like an idiot at the moment so please forgive my trivial questions.
1> When I originally set my up year and half ago - boatbod did my config file for me. I have tried to edit it since but anything I open and close the file with, the file no longer works and half to copy the one that he did for me back into its place for things to work.
I used nano and other Raspberry Pi text editors and this just keeps happening.
What do I do to fix this?
2> I am in Carroll County Maryland and it is configured for my country. I want to now add local township frequencies that are not the county. How do I do this? (assuming my issue above gets resolved.
boatbod
Talbot Co, MD
Hi -
Two options... use the new cfgtrunk.py tool, or pm me and I'll try to straighten out your trunk.tsv.
studysession
Carroll County, MD
Hi -
Sorry for the long time between reply's. As we all know life has been a bit off.
Today I downloaded your latest github version. I downloaded the latest copy of noobs and installed the full desktop. I am using a Raspberry Pi 3 B+.
Code:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install gnuradio gnuradio-dev gr-osmosdr librtlsdr-dev libuhd-dev libhackrf-dev libitpp-dev libpcap-dev git doxygen
cd ~
git clone git://op25.osmocom.org/op25.git
cd op25
mkdir build
cd build
cmake ../
## I have a note back from when you helped me in 2018 to use the -j6 after make.
make -j6
sudo make install
sudo ldconfig
At the moment - it doesn't matter if I use make or make -j6 it just aborts.
fatal error: ittp/comm/bch.h: No such file or directory
Tried capturing the screen using my phone but the forum says the pic is too big to upload.
Thanks for your help
Keith
a417
make -j(x) just forces make to use multiple processor cores/threads...your issue is that a linked file is not found. They are separate and distinct.
boatbod
Talbot Co, MD
Your notes above suggest you're actually using the osmocom version of op25, not mine.
For mine, do the following:-
Code:
cd ~
mv op25 op25.osmocom
git clone https://www.github.com/boatbod/op25
cd op25
./install.sh
