Hello All,
I am starting to delve into OP25 (Boatbod's fork). I am using an RPi4 with 4Gb RAM with an RTLSDR. Having some problems, however.
I install OP25 and am able to get the system display running (the one showing the system info and TG activity.
I start to run into trouble when I configure further and mess with the trunk.tsv and TGID tags file. I am using LibreOffice and once I attempt to configure the system name in trunk.tsv as well as the TGID tags file, ./op25.sh doesn't do anything. It pauses for a moment and goes back to the empty command line.
sysname control_channel_list offset nac modulation tgid_tags_file whitelist blacklist center_frequency
OC_CCCS 856.7125,857.4625,860.2125,860.4625 0 0 cqpsk OC_CCCS
I am attempting to monitor the Orange County CCCS:
I have only altered those 2 files. Any suggestions would be much appreciated. I am taking baby steps here trying to get audio and the HTTP console working eventually.
Thanks,
Countywide Coordinated Communications System (CCCS) (P25) Trunking System, Orange County, California
Countywide Coordinated Communications System (CCCS) (P25) Trunking System Profile
www.radioreference.com
Thanks,
