robocock8191
Hi everyone,
I have recently just gotten my RTL-SDR and have setup OP25 on a Ubuntu virtual machine on my macbook.
Was running quite well. Today I was getting many encrypted transmissions on TG's I hadn't blacklisted yet.
So I would quit op25, add the TG to my blacklist in the Trunk.tsv file, then restart OP25.
I feel like the last time I maybe quit too fast, as if it were barely finished loading up. And since then OP25 will no longer run. I have tried replugging my SDR, rebooting the system but no joy unfortunately
It starts to load then just spits me back out at the terminal prompt. No error given.
Here is the contents of my stderr.2 file
Any help would be greatly appreciated. I don't really wanna trash the virtual machine and start again.
Cheers
RC
Code:
gr-osmosdr v0.1.x-xxx-xunknown (0.1.5git) gnuradio 3.7.11
built-in source types: file osmosdr fcd rtl rtl_tcp uhd plutosdr miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Using device #0 Realtek RTL2838UHIDIR SN: 00000001
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Using two-stage decimator for speed=2400000, decim=25/4 if1=96000 if2=24000
Project 25 IMBE Encoder/Decoder Fixed-Point implementation
Developed by Pavel Yazev E-mail: pyazev@gmail.com
Version 1.0 (c) Copyright 2009
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio::open_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1], do_nocrypt[0]
Reading blacklist file
Traceback (most recent call last):
File "./rx.py", line 934, in <module>
rx = rx_main()
File "./rx.py", line 848, in __init__
self.tb = p25_rx_block(self.options)
File "./rx.py", line 198, in __init__
self.open_usrp()
File "./rx.py", line 775, in open_usrp
self.__set_rx_from_osmosdr()
File "./rx.py", line 703, in __set_rx_from_osmosdr
self.__build_graph(self.src, capture_rate)
File "./rx.py", line 325, in __build_graph
self.trunk_rx = trunking.rx_ctl(frequency_set = self.change_freq, debug = self.options.verbosity, conf_file = self.options.trunk_conf_file, logfile_workers=logfile_workers, meta_update = self.meta_update)
File "/home/kevinburton/op25/op25/gr-op25_repeater/apps/trunking.py", line 765, in __init__
self.build_config_tsv(conf_file)
File "/home/kevinburton/op25/op25/gr-op25_repeater/apps/trunking.py", line 859, in build_config_tsv
self.setup_config(configs)
File "/home/kevinburton/op25/op25/gr-op25_repeater/apps/trunking.py", line 917, in setup_config
self.configs[nac][k] = get_int_dict(configs[nac][k])
File "/home/kevinburton/op25/op25/gr-op25_repeater/apps/trunking.py", line 699, in get_int_dict
return dict.fromkeys([int(d) for d in s.split(',')])
ValueError: invalid literal for int() with base 10: ''
Cheers
RC
