kc2klc
I have successfully been monitoring the local (Broome County, NY) APCO-P25 Phase II system using Boatbod OP25 with an RTL-SDR V3 blog connected to a Raspberry Pi 4B. My trunk.tsv is:
"Sysname" "Control Channel List" "Offset" "NAC" "Modulation" "TGID Tags File" "Whitelist" "Blacklist" "Center Frequency"
"Broome" "453.8375" "0" "0x2a8" "cqpsk" "broome.tsv"
And the command line I use is:
./rx.py --args 'rtl' -N 'lna:35' -S 2500000 -O pulse -T trunk.tsv -v 5 -V -2 -U 2> stderr.2
There is a broome.tsv file that contains the talkgroup IDs.
I now want the ability to monitor NYSEG (the installation came with a nyseg.tsv that apparently has the right control groups listed). Using SDR++, I see a nice strong signal on their control frequency (152.0825). I edited the trunk.tsv as follows:
"nyseg" "152.0825" "0" "0x2a8" "cqpsk" "nyseg.tsv"
And used the same command line, only substituting "-w" for the "-V". However, the tsbks counter is not incrementing - so it doesn't appear to be working.
Any idea where I went wrong? And how I can easily switch between Broome & NYSEG (short of writing a shell script to modify trunk.tsv every time I want to switch)? Thanks!
