azduststorm
KJ7QVY
- Joined
- Oct 25, 2016
- Messages
- 223
Okay will do thank you for all your time and help I really appreciate it.Both the Florence frequencies are P25 Conventional (non-trunked) unlike the Sheriff's Office which is on the Pinal County P25 System. You can monitor either one of these using OP25's rx.py using the "-f frequency" option but unfortunately the "-T trunk.tsv" trunking config isn't going to help you.
Monitoring both frequencies simultaneously using a single RTL dongle should be possible with multi_rx.py but the configuration file is very different from what you are using now. Suggest you take a look at the "p25_conventional_example.json" file found in the ./apps directory for how to set up a 2 channel P25 Conventional system.
Good morning, I filled out all the info on the p25_conventional_example.json" file. on not sure how to write out the start command. can you help me on this matter please?Both the Florence frequencies are P25 Conventional (non-trunked) unlike the Sheriff's Office which is on the Pinal County P25 System. You can monitor either one of these using OP25's rx.py using the "-f frequency" option but unfortunately the "-T trunk.tsv" trunking config isn't going to help you.
./multi_rx.py -v 1 -c your_config_script_name.json 2> stderr.2
thank you tried and didn't workCode:./multi_rx.py -v 1 -c your_config_script_name.json 2> stderr.2
What was the error or log file output?thank you tried and didn't work
There wasn't any error logs file or out put. It just went back to a new lineWhat was the error or log file output?
cat stderr.2
it shows thisRun this to actually view what's inside the stderr.2 file, or locate it in the file browser and open it with a text editor. All the 'error' messages get dumped into it when you run the command with 2> stderr.2
Code:cat stderr.2
I think the file name is wrong. Its coming out as an .txt file, not sure how to change it if it is wrong.It says it can't find florencepoliceandfire.json, so either the file name is wrong or doesn't exist, its in the wrong directory, or you are launching from the wrong directory. Probably easiest to make sure your start script, json file (spelled the same in the command as the file name) and your terminal are all in the apps directory when starting up.
Thank you for the information. I tried that command line again with the correct file still nothing. I recently had to reformat my card and put everything back in . I am back to my first issue, I had with op25, not recognizing the 3.5 inch screen.
Good morning,
