Have you configured your trunk.tsv file yet? What system are you going to be monitoring?
So how do I go about setting up "rx.py command line options" trunk.tsv etc. I've thought about trying to play around and see if I could figure it out but at the risk of losing something or worse screwing it up, I think I'll leave it alone till someone who knows better can advise me.
The main one
1 (1)023 (17)FordFord851.8375852.4625c852.725a852.975853.400853.8625
Optional but highly wanted
1 (1)024 (18)AshlandClark851.425851.7375c852.0625a852.3875853.375853.675
1 (1)026 (1A)JetmoreHodgeman851.7125852.4875c852.775a853.075853.425853.725
1 (1)027 (1B)IngallsGray851.600852.3125c852.6125a852.9375853.1875853.650
Also is it possible to have op25 run automatically when the pi is powered on?
That is correct. You can "git pull" from any directory as long as it's inside the op25 hierarchy.When I had to do one, I was told to do it from anywhere inside op25, hope that helps.
https://forums.radioreference.com/threads/new-op25-goto-featurette.380534/#post-3036980
Please post a screen shot of the error.I keep getting permission denied
Not sure where to start here...much to explain.I was trying to drag and drop I doubted it would work but I suck with linux and would have no idea what command to use
cd ~/op25/op25/gr-op25_repeater/apps
ls -al
Check your typing"No such file or directory"
