Hey,
Thanks to boatbod's setup, OP25 is running nicely on an old laptop I had running Ubuntu 18.04. The only weird issue is that it seems like the SDR's noise floor's do not change significantly when messing with the -N 'LNA:xx' setting in OP25. The noise floor from what I have seen in GNU radio and SDR# should be much higher given that gain setting.
I can't seem to find the signal I am looking for in OP25, which I can find in other SDR software using the same hardware/config, since it appears the gain settings aren't changing on the SDR?
Attached are two examples of LNA set to 27 and 47.
Thanks for any insight,
Joe
Joe
