jm650
I am OP25 from Osmocom. I have applied the GR3.8 patch and I am starting OP25 like this,
and I get this error...
There are multiple audio devices on the system. Each device throws back a different 'bytes like object' error. The the sound device on the motherboard throws this error, for example
Got any ideas?
Code:
./rx.py --nocrypt --args "rtl" --gains 'lna:36' -S 960000 -X -q 1 -v 0 -2 -V -U -T trunk.tsv -U -O plughw:2,0
Code:
apps# tail -30f /tmp/outfile
This is free software, and you are welcome to redistribute it
under certain conditions; see the file ``LICENSE'' for details.
op25_audio::open_socket(): enabled udp host(127.0.0.1), wireshark(23456), audio(23456)
p25_frame_assembler_impl: do_imbe[1], do_output[0], do_audio_output[1], do_phase2_tdma[1]
Allocating 15 zero-copy buffers
__set_rx_from_osmosdr(): failed to set frequency
Using two-stage decimator for speed=960000, decim=10/4 if1=96000 if2=24000
added talkgroup 3405 from whitelist.txt
added talkgroup 3407 from whitelist.txt
added talkgroup 3606 from whitelist.txt
added talkgroup 3707 from whitelist.txt
added talkgroup 5503 from whitelist.txt
added talkgroup 6008 from whitelist.txt
added talkgroup 7455 from whitelist.txt
added talkgroup 7556 from whitelist.txt
added talkgroup 7605 from whitelist.txt
added talkgroup 7712 from whitelist.txt
added talkgroup 10005 from whitelist.txt
audio device: plughw:2,0
python version detected: 3.8.5 (default, May 27 2021, 13:30:53)
[GCC 9.3.0]
Exception in thread Thread-3:
Traceback (most recent call last):
File "/usr/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/home/jason/src/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 320, in run
data_a = self.scale(data_a)
File "/home/jason/src/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 338, in scale
pcm_r = struct.unpack('<h', next(iter_d, chr(0)) + next(iter_d, chr(0)))[0]
TypeError: a bytes-like object is required, not 'int'
Code:
audio device: plughw:1,0
[GCC 9.3.0]
self.run()
File "/home/jason/src/op25/op25/gr-op25_repeater/apps/sockaudio.py", line 296, in run
flag_a = ord(in_a[0][0]) + (ord(in_a[0][1]) << 8) # 16 bit little endian
TypeError: ord() expected string of length 1, but int found
Got any ideas?
