OP25 (Osmocom) high CPU usage, error on start up.
jets1961
Hi all, I am getting high CPU usage running the latest OP25 (Max-Osmocom) version, native Ubuntu 22. Screen shot attached and the following startup error;
"Traceback (most recent call last):
File "/home/user/op25/op25/gr-op25_repeater/apps/sql_dbi.py", line 79, in insert_row
self.cursor.execute(d['command'], d['row'])
sqlite3.OperationalError: no such table: data_store"
Is this because I have not created a blank log file and am not pointing to it? If so where do I reference the location of the log file in my trunk.tsv is it after tgid.tsv file refernce?
Do you think this could cause the high CPU usage?
Here is command line: ./rx.py --args "rtl" --gains 'lna:22' -S 960000 -X -P fft,symbol -d -100 -q -8.1 -l http:127.0.0.1:5000 -v 3 -2 -V -U -T wpg700a.tsv 2> stderr.2
jets1961
When I look at process view they two process using anything at pyton3 and firefox (106).
What about the error, if I fix it maybe the high usage goes away? I know in pass version had way lower CPU usage...
wgbecks
NE Wisconsin
The Traceback suggests the SQL database is not present or has not been initalized. However, there is a potential conflict with the port number
chosen to host the http console. Port 5000 is the by default the port used by oplog (Flask). You'll need to use a different port for one or the other to avoide a conflict if you intend to run op25 and oplog together.
Bill
jets1961
I thought I would update this thread.
While doing routine updates to the Ubuntu 22.04.1 system I noticed it did an update to python3. Since the update the high CPU usage has ceased. Down from about 21% to 5%.
So this is resolved.
