OP25 OP25 persistent error
ewh01
vineland, nj
I am running boatbod OP25, starting via ./rx.py. It will run for a while, but at random times it will lock up, each time the stderr file shows the error below
cb transfer status: 5, canceling...
rtlsdr_read_async returned with -5
04/11/24 22:21:34.293170 UI Timeout
04/11/24 22:21:44.306421 UI Timeout
04/12/24 03:21:40.543843 UI Timeout
04/12/24 03:21:46.553775 UI Timeout
04/12/24 07:21:44.473553 UI Timeout
04/12/24 07:21:57.488033 UI Timeout
main: exception occurred
main: exception:
Traceback (most recent call last):
File "/home/******************/op25/op25/gr-op25_repeater/apps/./rx.py", line 1021, in run
time.sleep(1)
KeyboardInterrupt
Does anyone know what is going on and/or how to fix this?
wgbecks
NE Wisconsin
It looks like a loss of USB connectivity with your SDR dongle. Check that your SDR's USB connections are mechanically and electrically secure and don't overlook the SDR itself or a faulty USB hub or extension cable(s) if used.
ewh01
vineland, nj
OK, I'll try a different USB port.
It just happened again, and I got the following from running tail -f
04/12/24 11:56:26.502804 voice update: tg(5261), freq(769781250), slot(1), prio(3)
boatbod
Talbot Co, MD
Those are definitely errors that you see when the rtl driver looses contact with the hardware device. I've seen it happen under several different conditions:
- RPI with inadequate power supply (low voltage)
- RTL with intermittent USB connector (i.e. a physical issue)
- RTL device going bad (i.e. an electrical issue)
ewh01
vineland, nj
Looks like it's time for a new dongle!!
Thanks folks!!
