OP25 Radio ID Tags
boatbod
Talbot Co, MD
If have added Radio Id alpha tagging for the multi_rx.py version of op25. The rid_tags.csv file follows the same format as trunk-tags.csv (i.e. numeric_id<tab>text_string) and is enabled by specifying the filename from cfg.json trunking section using the "rid_tags_file": parameter. See p25_rtl_example.json
Notes:
i. tags are truncated to 14 characters on the curses terminal, but there is no defined max length on the http terminal.
ii. tags are not supported when using rx.py
