Opelika TRS Help
dgoodson
North Florida
I programmed the Opelika TRS system into my 396T using the parameters from the data base, but did not hear a peep. Suggestions appreciated.
k4sgt
Opelika has already been rebanded. Have you flashed your 396T yet?
k4sgt
Hmm...I just noticed that I am hearing PD traffic on the old PD VHF repeater. A dispatcher must have it patched with the 800 digi dispatch talkgroup. You will not hear the dispatcher, as it doesn't appear to be set up multiselect, but you get to hear all of the field units. Seems out of place to hear the characteristic digital audio on an analog repeater. Either way, if anyone doesn't have digital capability and can not listen to the Opelika PD...well you can now.
155.670 Mhz analog
k4sgt
Sorry, no. They unpatched it. Probably was patched by mistake in the first place. You may occasionally hear traffic on this VHF repeater, but not much.
k4sgt
So, tell me. Why do you think that the Opelika 800mhz trunking system was patched to the VHF repeater for system maintenance? Do you have inside information or are you just assuming? Just wondering. Thanks.
dgoodson
North Florida
I ultimately found my "problem" was that I had set the system in my 396T as if it were a P25 system rather than a plain vanilla Moto Type 2. Working fine now (when programmed as 800MHz Type 2)... Not sure what steered me to set it up as a P25, I think I was thinking that if it were rebanded, it must be P25.
k4sgt
No, all that I did to reband the system was to change some of the system frequencies to a lower frequency (including two of the four control channels). The system is still SmartNet Motorola Type II running in mixed analog and ASTRO. I am glad to hear that you got your scanner going with it, though. Happy scanning!
