ProScan: Open a specific com port on launch?
PhillyPhoto
Wethersfield, CT
Is there a way to pass a variable to ProScan when it launches to open a specific com port? I have 2 scanners connected, and when I open a second instance, I have to set a different com port, and I was wondering if I can create a second shortcut with something like this in the target:
"C:\Program Files (x86)\ProScan\ProScan.exe" -com 4
ProScan
Software Provider
Ontario, Calif.
Negative. No need to.
ProScan will load using the the same comm. port that it was using when ProScan closed.
Is the other instance in a seperate folder?
buddrousa
NW Tenn
I bet the OP is not running 2 separate copies of PROSCAN they are running the same copy.
INSTALL A SECOND COPY AND FORCE IT TO BE IN A DIFFERENT FOLDER.
I know it works I am 16 copies all in different folders connected to 16 different Uniden Scanners.
