I just installed OpenGD77, did not like it and went back to the original firmware. Keep in mind you can no longer use the same CPS you where using after you install OpenGD77, it will not be able to communicate with the radio. The steps bellow is what I did (in win7) to revert back to the original FW. Just need to download the latest firmware and CPS at the Radioddity website, there are multiple links at the download section.
At the same time of reverting back upgraded the radio from previous FW v4xxx straight to v6.01.00, unfortunately don't have the exact link where I downloaded the file, but I would think it was also on the Radioddity website as well. The file I used that has the v6 FW release is called:
"2021-01-26_GD-77_CPS_&_Firmware_Changelog_Commercial_Part90_Version.zip" and as the name implies contains both the FW, the FW updater, and the corresponding CPS (v3.1.9) to be able to program the radio after the new firmware has been installed.
Download this FW/CPS file and unzip the files to a directory, then run the firmware installer, and from the updater screen browse to the desired firmware file called "GD-77_V6.01_Part 90 Firmware.sgl". Also make sure to select the correct com port on the installer (check device manager to see which port has been assigned to the programming cable). Then click the Download button and the radio should then be updated.
At least for me it worked perfectly and I am back to the original FW without any issues and not having lost the codeplug or anything else that was originally in the radio.
