Open squelch at the end of Transmission
ausscan
I ca't work out what setting needs adjusting on my (U)BCD396XT - There is an audible hiss like an open squelch at the end of a Trunked P25 transmission where the scanner receives the LNK and goes back down to the control channel.
bchibb
Mine does the same thing. I have not found a setting that will eliminate this noise.
jubis09
williston, fl
i have same issue...i have turned the end code setting to analog+digital...hopefully this will work. have you resolved your issue? if so how?
