openBTS is not installaing
vijay_eee
bangalore
I have installed openbts in ubuntu 12.04 LTS , while installing it is showing error transcever not installed i have tried by installing it manually but no use, openbts is not starting on my system can i get a solution for this problem
The error what i am getting while installing is
ALERT 14235:14246 2015-07-23T13:06:05.0 OpenBTS.cpp:174:startTransceiver: starting transceiver ./transceiver with 1 ARFCNs
EMERG 14235:14249 2015-07-23T13:06:05.0 OpenBTS.cpp:180:startTransceiver: cannot find ./transceiver
EMERG 14235:14246 2015-07-23T13:06:05.0 OpenBTS.cpp:185:startTransceiver: Transceiver quit with status 256. Exiting.
for transreciver problem what i mentioned in pevious post i just copied transreciver execution file present in transreciver52m directory to apps directory,
after that it is asking no uhd device,
i connected B210 and tried the procedure again
i am facing an error
UHD Error:
An unexpected exception was caught in a task loop.
The task loop will now exit, things may not work.
RuntimeError: usb rx8 transfer status: 5
in new terminal if i give uhd_find_devices then no devices are detecting.actually uhd is installed and it detected usrp before openbts installation
error
UHD Error:
USB open failed: insufficient permissions.
See the application notes for your device.
No UHD Devices Found
can any one give solution for this problem
i am using ubuntu 14.04, GNU C++ version 4.8.4; Boost_105400; UHD_003.009.git-208-g2563456f
Thanks in Advance
