What are your readings with a rubber duck antenna?I started reading this thread without a tremendous amount of interest, but now I am interested. I'm getting consistent RSSI readings of greater than -100db. I know that there are a lot of variables, but I'm using a discone type antenna so maybe should get better signal than I am.
The closest NOAA station is about 5 air miles from my house and I'm getting -67db.
Again, I know that there are a lot of variables, but is it likely that there is an issue with my new SDS100?
Your rssi should be fairly low. Definitely under 100 and probably under 80 as well. You may have the same problem I had.On a quick test, they are better with the outside antenna than with the RS800 antenna. That's on the state police trunk site. Not a lot better as far as RSSI is concerned, but the audio is clearer.
I'll do some more testing over the next couple days. I replaced the cable that goes to the SDS100 because I think there might be a problem with the F connector (the way I installed it).
So I recently sent in my SDS100 for a volume knob repair. It came back receiving absolute garbage for transmissions.
Correct.What happend to the gob of white goop they put in there to help make it water proof? Lools like they cleaned it all out and didn't put any back?
My 536HP had 500% better reception than my SDS100. It was absurd.What makes me think it might be my antenna system is that the 536HP next to the SDS100 and on the same antenna receives more or less the same. As does the SDR set up I'm also running. All of that is running off or a Electroline four port splitter/amplifier. The antenna is new as of the fall. As is the cable, but that might be the weak link. All I had available at the time was RG 59. Since then I bought double shielded RG6 cable. Which will go up in the spring when the weather breaks.
That will be well within the warranty period, plus I'll be able to talk the SDS100 mobile and try from different locations with different antennas.
By spring I'll have a much better idea of what's going on.
Correct.
