The U.S. Federal Communications Commission was created by an act of Congress in 1934 for purposes of regulating telecommunications in the U.S.
The following is from the United States Code:
47 U.S. Code § 151 - Purposes of chapter; Federal Communications Commission created
For the purpose of regulating interstate and foreign commerce in communication by wire and radio so as to make available, so far as possible, to all the people of the United States, without discrimination on the basis of race, color, religion, national origin, or sex, a rapid, efficient, Nation-wide, and world-wide wire and radio communication service with adequate facilities at reasonable charges, for the purpose of the national defense, for the purpose of promoting safety of life and property through the use of wire and radio communications, and for the purpose of securing a more effective execution of this policy by centralizing authority heretofore granted by law to several agencies and by granting additional authority with respect to interstate and foreign commerce in wire and radio communication, there is created a commission to be known as the “Federal Communications Commission”, which shall be constituted as hereinafter provided, and which shall execute and enforce the provisions of this chapter.
The following references are from the Code of Federal Regulations:
§ 1.903 Authorization required.
§ 2.405 Operation during emergency.
The licensee of any station (except amateur, standard broadcast, FM broadcast, noncommercial educational FM broadcast, or television broadcast) may, during a period of emergency in which normal communication facilities are disrupted as a result of hurricane, flood, earthquake, or similar disaster, utilize such station for emergency communication service in communicating in a manner other than that specified in the instrument of authorization: Provided:
Note:
Part 73 of this chapter contains provisions governing emergency operation of standard, FM, noncommercial educational FM, and television broadcast stations. Part 97 of this chapter contains such provisions for amateur stations.
§ 90.203 Certification required.
§ 95.335 Operation of non-certified transmitters prohibited.
Except as provided in paragraph (a) of this section, no person shall operate a transmitter in any Personal Radio Service unless it is a certified transmitter; that is, a transmitter of a type which has obtained a grant of equipment certification for that service, pursuant to part 2, subpart J of this chapter. Use of a transmitter that is not FCC-certified voids the user's authority to operate that station. See sections 302(a), (b), and (e) of the Communications Act (47 U.S.C. 302(a), (b), and (e)).
§ 97.3 Definitions.
§ 97.403 Safety of life and protection of property.
No provision of these rules prevents the use by an amateur station of any means of radiocommunication at its disposal to provide essential communication needs in connection with the immediate safety of human life and immediate protection of property when normal communication systems are not available.
(a) General rule. Stations in the Wireless Radio Services must be used and operated only in accordance with the rules applicable to their particular service as set forth in this title and with a valid authorization granted by the Commission under the provisions of this part, except as specified in paragraph (b) of this section.
(b) Restrictions. The holding of an authorization does not create any rights beyond the terms, conditions and period specified in the authorization. Authorizations may be granted upon proper application, provided that the Commission finds that the applicant is qualified in regard to citizenship, character, financial, technical and other criteria, and that the public interest, convenience and necessity will be served. See §§ 301, 308, and 309, 310 of this chapter.
(a) That as soon as possible after the beginning of such emergency use, notice be sent to the Public Safety and Homeland Security Bureau of the Commission at Washington, D.C., stating the nature of the emergency and the use to which the station is being put, and
(b) That the emergency use of the station shall be discontinued as soon as substantially normal communication facilities are again available, and
(c) That the Public Safety and Homeland Security Bureau of the Commission at Washington, D.C., shall be notified immediately when such special use of the station is terminated: Provided further,
(d) That in no event shall any station engage in emergency transmission on frequencies other than, or with power in excess of, that specified in the instrument of authorization or as otherwise expressly provided by the Commission, or by law: And provided further,
(e) That any such emergency communication undertaken under this section shall terminate upon order of the Commission.
Note:
(a) Except as specified in paragraphs (b) and (l) of this section, each transmitter utilized for operation under this part and each transmitter marketed as set forth in § 2.803 of this chapter must be of a type which has been certified for use under this part.
(1) Effective October 16, 2002, except in the 1427-1432 MHz band, an equipment approval may no longer be obtained for in-hospital medical telemetry equipment operating under the provisions of this part. The requirements for obtaining an approval for medical telemetry equipment after this date are found in subpart H of part 95 of this chapter.
(2) [Reserved]
(3) Any manufacturer of radio transmitting equipment (including signal boosters) to be used in these services may request certification for such equipment following the procedures set forth in subpart J of part 2 of this chapter. Certification for an individual transmitter or signal booster also may be requested by an applicant for a station authorization by following the procedure set forth in part 2 of this chapter. Such equipment if approved will be individually enumerated on the station authorization.
(e) Except as provided in paragraph (g) of this section, transmitters designed to operate above 25 MHz shall not be certified for use under this part if the operator can program and transmit on frequencies, other than those programmed by the manufacturer, service or maintenance personnel, using the equipment's external operation controls.
(g) Transmitters having frequency programming capability and that are designed to operate above 25 MHz are exempt from paragraphs (e) and (f) of this section if the design of such transmitters:
(1) Is such that transmitters with external controls normally available to the operator must be internally modified to place the equipment in the programmable mode. Further, while in the programmable mode, the equipment shall not be capable of transmitting. The procedures for making the modification and altering the frequency program shall not be made available with the operating information normally supplied to the end user of the equipment; or
(2) Requires the transmitter to be programmed for frequencies through controls normally inaccessible to the operator; or
(3) Requires equipment to be programmed for frequencies through use of external devices or specifically programmed modules made available only to service/maintenance personnel; or
(4) Requires equipment to be programmed through cloning (copying a program directly from another transmitter) using devices and procedures made available only to service/maintenance personnel.
(a) Exceptions. Under certain exceptions, non-certified Personal Radio Service transmitters, or transmitters certified for use in the land mobile radio services may be operated. Any such exceptions applicable to stations in a Personal Radio Service are set forth in the subpart governing that specific service. See e.g., §§ 95.735 and 95.1735.
(b) Revoked or withdrawn certification. In the event that the FCC revokes or withdraws a grant of equipment certification for a type of Personal Radio Service transmitter, existing transmitters already in service may continue to be operated unless and until the FCC determines otherwise and gives Public Notice of that decision.
(c) Grantee permissible modifications. Only the grantee of the equipment certification may modify the design of a certified Personal Radio Service transmitter type, and then only pursuant to and in full compliance with the requirements and procedures for permissible changes and modifications in part 2 of this chapter. See §§ 2.932 and 2.1043 of this chapter.
§ 97.3 Definitions.
(a) The definitions of terms used in part 97 are:
(1) Amateur operator. A person named in an amateur operator/primary license station grant on the ULS consolidated licensee database to be the control operator of an amateur station.
(2) Amateur radio services. The amateur service, the amateur-satellite service and the radio amateur civil emergency service.
(4) Amateur service. A radiocommunication service for the purpose of self-training, intercommunication and technical investigations carried out by amateurs, that is, duly authorized persons interested in radio technique solely with a personal aim and without pecuniary interest.
(5) Amateur station. A station in an amateur radio service consisting of the apparatus necessary for carrying on radiocommunications.
