TheJerk
I have been off the air too long, finally just put up my little telescopic antenna just to get real local stuff. I live in an area that typically receives several snow/sleet/ice storms every winter.
Here are my options (roof mounting is not an option):
Install a short tower to about 20 feet...either install my ST2 (which most likely won't last long here between wind/ice) or install a single stainless steel whip. This will require significant grounding (as discussed in other threads) and a significant run of coax (about 100 feet) to do it correctly.
Install the ST2 in the 3rd floor walk-in attic (very easy to do) with about 25 feet of RG8U. I could also do a simple/custom wire dipole (up to 50 feet long) in this location, if it would offer me anything better. (on a side note, how would I ground this antenna? Would tying into the house ground be sufficient?)
While the antenna would be inside, it would be physically higher than any tower I would install. However, we get snow here quite a bit, and I'm not sure how that would affect reception with a snow covered roof.
Thoughts? I'm leaning toward installing in the attic, and forgetting about the tower.
