Hope I didn’t mess up. Wife was helping me feed the LMR400UF and it got into a circle about 1” diameter. I read the minimum bend radius is much more than that. Did I break something inside the coax by bending it that tight? It is hooked up and I am getting everything I was before and the signal strength meter on the SDS200 shows more bars.
Second goof - I forgot to turn the scanner off before I cut the old coax. Did that harm anything on my SDS200? Again, everything seems to be fine.
I’m too old to be on the roof.
If it just got into a kink, and you didn't yank on it to forcefully pull it thru a binding point, and you carefully worked the kink out and untwist it - you are likely ok.
If you got it into a bind and then yanked the hell out of it to force it loose, damage is considerably more likely. Check for continuity from center conductor to shield if you are that concerned. If this is RX only, you'll probably be ok. If you're pushing huge wattage out it - i'd be more leery.
Here's a screenshot from the Times LMR spec sheet to calm some of those nerves. Look at the top line on the left. It's almost like they foresaw that happening...
Disconnecting a RX only devices' antenna is significantly less likely to damage it, as you are not transmitting. Transmitter finals dislike that significantly more.
