Opinions on NMO Install Location
Moto_user
Florida
I currently have an NMO mount on the center of the roof of my truck and am considering purchasing a new vehicle. On my current vehicle, the AM/FM antenna is on the corner of the hood of the passenger side and the GPS/Sirius XM antenna is on the front left corner of the roof. The new model year has an all in one GPS/SiriusXM and terrestrial radio antenna at the back of the roof (pictured below). Due to the moonroof, it only leaves a small section towards the back for an antenna install for a dual band (2m/70cm) mobile radio and if I purchased this vehicle, I would likely install the NMO to the right or left of the antenna. I would expect to receive interference on FM broadcast when transmitting on 2meters due to the close proximity to the reception antenna but what is everyone's opinion on possible interference on GPS/Sirius XM reception? I know there is a large spread between those two bands but does anyone have any experience with whether I would likely have interference or not? I've included a photo of the roof of the new vehicle below. Thanks!
LATA 722
I have a 50 watt VHF radio feeding a permanent mount NMO with a 1/4 wave antenna on top of my wife's truck. The antenna is about 18" from the AM/FM/XM/GPS antenna. No issues with it. Have not heard any issues with the satellite radio while transmitting.
mrweather
I've got a 1/4 wave UHF NMO antenna on my roof about 8" from the factory SXM/GPS sharkfin (similar issue with real estate due to the sunroof). I've had the satellite radio drop out when transmitting on certain UHF frequencies.
K6GBW
Montebello, CA
I ran two antennas on either side of my AM/FM antenna on my Chevy Colorado and they worked fine. The only issue I had was when transmitting DMR it got into my speakers...even with the radio off. I put some snap on ferrites on the speaker wires and that solved that problem. So you should be fine on the roof you describe. BTW, the Comet B10NMO is a good looking and good working antenna. That's what I had and it was fantastic.
