opp 10 codes
redhead
ottawa
hello out there i am looking for the opp 10 codes. please help, thanks
transam76
Chatham Ont
Hi forts, thanks for the 10 codes in knew most of all of them, but just wanted to brush up on a few. Its the other codes im looking for though, just wanted to know if you had them. There 500 or 700 something codes, never heard of them before, till i got this new scanner. I think there NCIC codes or something, from states.
Forts
Ontario, Canada
You are correct, NCIC is American. I believe you are referring to the CNI codes. Here is a quick summary of them.....
transam76
Chatham Ont
Thanks Forts for those codes, it must be them cause sometimes the opp use them. But i have a question why does it go like for example for theft 403-426 where are the numbers in between, say 404, 405 and so on. Is there more or is that just a briefing of them. This is the first time ive seen them, now i can least understand some off them if i memorize them (lol) :roll: I have one more question for you i seen in the database that some of the London police are in Anolog mode now, is this true, is it the Dispach Ch, cause i see op behind the name.
Forts
Ontario, Canada
The CNI codes listed above is just a summary. I can post a comprehensive list (or send it to you privately if you like).
As for London PD, all the good stuff is still digital. The OPS channels you see listed sound like they are vehicle operations, maintenance and such. Nothing to get very excited about I'm afraid. :(
transam76
Chatham Ont
Thanks again for the reply. If you can get the CNI codes to me would be very much appreciated. You can send them privately if you want or through here.
chevyman
Harriston, ON
If you're a member of the scanont yahoo group, the cni codes are listed on there under the files section
ftaking
ONTARIO PROVINCIAL POLICE 10 CODES:
10-1 through 10-10 same as common code
10-11 Dispatched too rapidly
10-12 Officials present
10-13 Existing conditions
10-14 Escort
10-15 Message delivered
10-16 Pick up prisoner
10-17 Go to ______
10-18 Complete assignment
10-19 through 10-21 same as common code
10-22 Disregard
10-23 Stand by
10-24 Assignment completed
10-25 Contact
10-26 Detain subject
10-27 Driver's license check
10-28 Vehicle registration check
10-29 Wants and warrant check
10-30 Improper use of radio
10-31 Pick up
10-32 Units needed
10-33 Emergency
10-34 Time check
10-35 Major alert
10-37 Drunk
10-38 Investigation alert
10-40 Advise if available
10-42 Not according to regulations
10-45 Fatality
10-46 Holding suspect
10-47 Ambulance needed
10-50 Subject negative
10-51 Tow truck needed
10-60 through 10-68 same as common code
10-69 Can you respond?
10-70 Subject in prohibition category
10-71 Subject in refused category
10-72 Subject in prohibited category
10-73 Subject in elopee category
10-74 Subject missing
10-75 Subject in pointer category
10-78 Officer needs assistance
10-90 Bank alarm
10-92 Person in custody
10-93 Road block
10-100 Bomb threat
