Drop your squelch a bit?
Thanks, yep I’ve usually got it set back a bit. Edgar AND Primrose are programmed in as per previous comment.
Still nothing.
It’s not telling you what tower you are listening to. Do you have the CC/VC selected in the settings? If you really want to see if you can hear Prinrose tower, go into EZ Scan and unselect all towered except Primrose snd load that configuration into your TRX-1. If you don’t see signal strength bars & the “T” for trunking, then you aren’t receiving Primrose tower.Three Bars Signal for Channel.
