OPP repeter freqs.
acab6
I cant seem to figure out that link you sent me, I'm knew to this and kinda lost, thanks for trying
n8chb
Its pretty stright forward,
Name search, frequency search etc.
for example if you know just one frequency you can find the others asociated with it.
The fcc data base works much the same as the Canadian one does although Canada does block some gov name searches.
73,
Roger
DaveH
Ottawa, Ont.
73,
Roger
OPP and other police forces do not show up on the Industry Canada
TAFL searches. No point looking for them there.
OPP uses the BMR (Bell Mobility Radio) Fleetnet Trunked VHF
system (Motorola) in three zones so far. All known data is on this
site (Database). Search under Motorola Trunked system IDs:
Zone 1 uses System ID 782d
Zone 2 uses System ID 822f
Zone 3 uses System ID 8230
There are non-trunked frequencies such as simplex and UHF
Vehicle Repeaters (VRs) also listed on this site.
Dave
n8chb
Dave
If that's so Dave what are these?
http://sd.ic.gc.ca/pls/eng_alpha/web_search.frequency_range_results
73
Roger
n8chb
n8chb said:
guess my link didn't work but this is an ascii printout.
If the original post would say what area he was looking for I would have looked it up for him.
138.105000 142.125000 ELGIN COUNTY MUNICIPALITY OF ST THOMAS FIRE DEPT
138.105000 142.305000 BARRIE, ONT. 201 GEORGIAN DR ROYAL VICTORIA HOSPITAL ATTN: LIANE COATES
138.165000 142.185000 CHATHAM/KENT CORPORATION OF THE MUNICIPALITY OF CHATHAM-KENT / FIRE DEPARTMENT
138.195000 142.215000 BRANTFORD, ON-MOBILE COMMAND CENTRE CITY OF BRANTFORD MUNICIPAL EMERGENCY PLANNING
138.255000 142.275000 OAKVILLE, ONTARIO AND AREA HALTON REGION (EMERGENCY PLANNING)
138.390000 142.410000 GUELPH AND AREA CITY OF GUELPH FIRE DEPARTMENT
138.495000 142.515000 OAKVILLE, ONTARIO AND AREA HALTON REGION (EMERGENCY PLANNING)
138.750000 142.770000 BRANTFORD, ON-MOBILE COMMAND CENTRE CITY OF BRANTFORD MUNICIPAL EMERGENCY PLANNING
138.750000 142.770000 OAKVILLE, ONTARIO AND AREA HALTON REGION (EMERGENCY PLANNING)
138.780000 142.800000 WAWA ONTARIO TOWNSHIP OF MICHIPICOTEN
138.780000 142.800000 WAWA ONTARIO TOWNSHIP OF MICHIPICOTEN FIRE DEPARTMENT
138.780000 142.800000 WAWA, ONTARIO AND AREA TOWNSHIP OF MICHIPICOTEN
138.780000 142.800000 WAWA, ONTARIO AND AREA TOWNSHIP OF MICHIPICOTEN LEISURE SERVICES
138.870000 142.890000 ONTARIO (SEE FREQUENCY CONDITIONS) Her Majesty The Queen in Right of The Province of Ontario (GMCO)
138.885000 142.905000 ATIKOKAN, ONTARIO TOWNSHIP OF ATIKOKAN FIRE DEPT. ATTN: GARTH DYCK
142.305000 142.305000 BARRIE, ONT. 201 GEORGIAN DR ROYAL VICTORIA HOSPITAL ATTN: LIANE COATES
142.800000 142.800000 WAWA ONTARIO TOWNSHIP OF MICHIPICOTEN
142.800000 142.800000 WAWA, ONTARIO AND AREA TOWNSHIP OF MICHIPICOTEN
142.800000 142.800000 WAWA, ONTARIO AND AREA TOWNSHIP OF MICHIPICOTEN LEISURE SERVICES
142.890000 138.870000 ONTARIO-WIDE (ML RPTRS) Her Majesty The Queen in Right of The Province of Ontario (GMCO)
DaveH
Ottawa, Ont.
Roger,
Sorry, sending that link doesn't work for me (shows 404 error).
Your search results depend on "cookies" set on your machine,
which are not sent with the link. Try a text cut/paste if
possible or describe what you found.
There may be some exceptions, but rather rare. Ottawa (Ont.)
PD has 25 frequencies in the 866-869 range and not one shows
up on any TAFL search I have seen. There is also a 5-channel
government trunked system in the same range and it doesn't
show either (it is System 2C1E, in the RR Database).
Some Ontario Gov't frequencies show up, mostly MOH (Health)
and MNR (Natural Resources).
The Ontario Gov't name for Fleetnet is GMCP (not to be confused
with GMCO). If that shows anywhere it would be most interesting.
Dave
n8chb
acab6 said:
I am looking for Toronto and the surrounding area
Send me an email message and I'll try and get you the info.
The data base is blocking that info or it's not up today.
Last year I downloaded some of the OPP locations and frequencys but not sure where I put them.
73
Roger
n8chb@wideopenwest.com
DaveH
Ottawa, Ont.
If there is/was a "backdoor" that would be most interesting,but
I doubt the average person can get around this blocking.
You may have found something listing its location as "OPP Tower"
which may be of interest, but it is not OPP (some services share
sites). Interpretation of the data is often necessary. Some of what
you list is MOH (e.g. 142.8900 repeaters).
FD does show up as long as it does not co-exist on a system
with PD or something else "sensitive". Ottawa PD is perfect
example; Ottawa FD and many City services share the EDACS system.
Individuals have collected extensive data on the Fleetnet systems
and it is in this Database. I am not aware of anything more
comprehensive.
Dave
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
For what it's worth, some "police" frequency allocations are making it into the TAFL, but usually when another agency is the one who is licensed. Example - local SAR group near me has a license to operate on the local RCMP repeater. SAR group shows to be licensed for that frequency. Nowhere in the listing does it indicate that it's a police frequency, but it is.
That's what the poster who c&p'd a list of OPP frequencies allocated to fire departments and hospitals has found.
jellotor
Hamilton, ON
Indeed...I believe the frequencies for the Halton Region EDACS system show up (at least in part) on TAFL because it was originally licensed for one or more fire departments.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Sorry bud but I don't see anything police related on that list. You've got a bunch of fire frequencies and one hospital.
TAFL is pretty much useless when it comes to Police Service searches. They fall within the definition of "Protected" frequencies.
