- Joined
- Apr 22, 2020
- Messages
- 432
So this is what happened with OCFA and surrounding OC agencies with the fire department talkgroups that went encrypted. There was a big push and a timeline for OCSD to switch over to the NextGen P25 TRS system. Each APX radio was manually programmed with all of the old zones and the new P25 zones which is still in the existing radios as of today.
I believe and might need to be corrected but the infrastructure was not put into place last June of 2019 and they scrambled and just threw everybody on the new system including fire. Even before like six months before the system went to the NextGen TRS system those new APX radios were bought which were like 7K radios give or take and they were manually programmed with the old system that was still in service and new zones were added for all of the fire agencies to be strapped with AES-256 without OTAR and OTAP enabled. The majority of OC fire agencies were still using XTS 3000 and 5000 Motorola radios so all of the fire agencies all got new APX radios.
So when the OCFA Chief wanted to reverse the encryption it should of been fairly easy maybe or maybe not with OTAR and this could of been done in a time of several weeks or so or a couple of months in waves. So its been 14 months now and nothing has changed.
Now with the county and this whole COVID-19 on-top of everything the county is probably going thru a short fall of a lack of tax payer dollars and the Chief did not realize the challenges of reversing encryption. Most likely instead of re-programming 10K radios most likely they will have to get OTAR and OTAP in place and then not have to manually re touch each radio.
