- Joined
- May 27, 2019
- Messages
- 4
There are two trunk systems called county wide when I try to import it imports the first one containing police and sheriff . The second one contains the fire groups.
ARC 500 PRO 197Ok what radio are you using and what software are you using to import and program the radio?
This has been fixed. For some reason the same trunked system was shown in two different categories (Sheriff and Fire), should have only been in one.
You may have missed Orange County, CA Fire Department Reverses Encryption Decision.All of Orange County police and fire departments are all encrypted. You will not get encryption on your radio or scanner. The Fire Department has been encrypted for over a year. The only way you can receive them is through Broadcastify.com.
My mistake based on what the database was showing. One would think that the local database administrator would keep the database updated with active encryption usage, but maybe the promise to reverse encryption is good enough to not properly update the database?They may have reversed the decision in June 2019, but everything still remains encrypted. It was promised to be unencrypted within three months after the reversal decision. I recommend you go back and review all the comments made pertaining to this, even back to January 2019 so you have a good history of what has transpired. I have been closely following this and am well aware of what's going on as I read all the posts.
IF / When someome makes a DB Submission
