Orange County Help with 996XT
waltmapb
Merritt Island, FL
I added a 996XT to my shack and can't seem to figure out how to program Orange County using FreeSCAN.
Is it a Motorola 800 Mhz Standard (Type II) or Motorola Custom/Rebanded Type II?
Is there an APCO 25 Band Plan ?
If its the rebanded type do I use the custom band plan on the East Central Florida Scanner website?
It sorta works as a 800 Mhz Standard but gets a lot of talk groups that are just static. If I try the Custom/Rebanded type it doesn't seem to track properly.
Phil
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you're talking about this system
Orange County Public Services (FL) Trunking System, Orlando, Florida - Scanner Frequencies
then see the FreeScan example in
Software Support for Uniden Rebanding
See the site type; note you will need a custom table. If you download from the database, FreeScan will set up the custom tables for you; but the article also gives you the values you will need if you choose to do it manually. Ignore the Apco band plan - it's a basically useless screen that was there for future use, but it seems, at least so far, no system uses it.
best regards...Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I just looked at the custom band plan on the East Coast Florida site, and it is incorrect. The first base frequency should be 851.025, not 851.0125.
I don't know if the gentleman who runs that site is here, but I'm going to send him an email with the correction. Hopefully not too many folks have been lead a bit astray by this.
73 Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
OK the custom table has been fixed - but the custom table as shown is only good for Uniden scanners. RS and GRE models use a slightly different custom table.
Section 7 of the rebanding article in the wiki has links to all the necessary changes, if anyone needs them.
best regards..Mike
waltmapb
Merritt Island, FL
Thanks - the settings are working.
If your talking about the East Central Florida site the frequency is still incorrect.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you looked at that site previously, do a page refresh or purge your history cache, and you'll see that it has been changed.
Glad to hear you got it working best regards..Mike
