Orange County Simulcast
WS595
Good evening,
I have noticed over the last couple of days on the Orange County Simulcast that the control channel 851.4125 keeps dropping and not supplying constant information so then the scanner cycles through the rest of the control channels in the system before locking back on and dropping again.
For now I've switched to monitoring the Orlando Simulcast system which is working perfectly.
Has anyone else noticed this issue? I am using an SDS100 with only the control channels programmed (I use site hold for either the Orange County Simulcast or Orlando Simulcast) and in the Eagle Creek area.
WS595
I will change back onto the Orange County sites instead of Orlando today and see what it does.
WS595
Yup I've just checked again and it isn't picking up a CC on the Orange County simulcast. Which CC frequency is yours locked to and where abouts in the county are you?
dkcorlfla
Orlando
I'm getting five bars on the 851.4125 CC BCD996P2. Discone up about 20 feet. Working fine here. My location is near the WPHS
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
Uniden scanners stupidly apply the squelch setting to the control channel, so if it's cranked up too high it won't decode properly. I think squelch=2 is the lowest it will go; squelch=1 is equivalent to squelch=0 on the BCD series.
WS595
You can go 0-15 on the SDS100 squelch.
