Well, I'm smart enough to figure out that the antenna goes at one end of the line, and the scanner goes at the other end.
But what order should lightning protector, (in my case Air band) pass filter & pre-amp be in?
I would think that the lightning protector shold be first, so that if/when hit, nothing past it would get damaged ..... I hope.
Next, I would think the filter should be, so that everything outside the air band (in my case) would be filtered out.
And finally the pre-amp, so that it will only amplify broadcasts within the frequency range that I'm interested.
Would the above be a pretty good assumption as to the correct order? Thanks in adbvance.
