Orion / Jaguar Audio Output Impedience
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Folks,
Does anyone know that the audio output impedance is for a MA/COM Mobile Radios?
I'm trying to interface some MA/COM Mobile equipment into an audio distribution system that runs on 4/8 ohms, and I'm not getting any audio into the switch from the radios.
Do I need an impedance matching transformer? Other considerations?
JungleJim
MMIC said:
It is an 8 ohm output, so it should work. What pins are you using?
That's incorrect. The Orion, J725m and M7100 have a 4 Ohm speaker impedance. You can hook up a higher impedance speaker like an 8 ohm or 16 ohm no problem, you just won't get as much audio out.
On solid state amplifiers you can have a higher impedance than rated but don't go lower.
MMIC
Inside of the circuit....
Oops, sure enough. I didn't find the specification on the first scan but I found it this time. I mis-interpreted a section of the installation manual, thanks for catching me :)
