Orion Mobile 800mhz PA problems
spratt
Alot of our Orion radios have a intermittent problem with the PA. Seems like its vibration related. We have several methods of getting the PA to xmitt again including a bang on the table.
Does any one know a permanant fix? Macom doest seem to have any answers for us
fishsqueezer
terre haute in
orion no tx power
cant find my maintenance manual but i have had several fail becauce of a bad chip resistor i think is 10 or 15 ohms next to tr22.it feeds power to driver module.
CCScan
Central Alabama
We too have had a lot of problems with our 800 MHz ProVoice Orions experiencing the same PA problems as well as receiver (un)sensitivity problems. Most can be fixed by reflowing the solder connections on P501/J501 connectors. This is the beige connectors, male and female, that connects the sythesizer board to the logic board. This should be done by someone with excellent soldering capabilities (qualified tech). By reflowing all the legs of each connector, you most likely will fix 90% of all your problems. At least we have. (VCO voltages, etc. pass thru this set of connectors)
I hope that helps. :)
CSHIFTLT
Henry
The j501 problem seems to lead to alot of diffrent problems,(no entry on radios to error 0603) after it is fixed flawless radio, really a factory problem.
cshiftlt
