Orion Provoice DSP With DES
BigLebowski
Piedmont NC
OK, probably it's nothing to worry about. If the radio has the means to accept a DES key the issue you're having when you press "PVT" is likely the absence of said key.
As it turns out.. the little LED next to the assigned button is working intermittently. I switched out the test head for the one I’m going to use and got it resolved. I also found it’s easier to just set Private mode to “Forced On” and make a separate zone (system) for my “Unencrypted” Provoice channels.
