Orion Questions ..
Two questions .. sorry if they are dumb questions. But I will try to make some sense.
First ... is there any difference in how you go about programming an Orion versus a handheld. For example an LPE. Are there any Orion options that I should be aware of that are common programming stumbling blocks.
Secondly .. where can I obtain the latest files for the Orion (straight Edacs models) ? Can they be downloaded from somewhere ?
Liberator
You program the Orion by attaching the programming cable and then power up the radio. The Orion will display "PROGRAM" and that's it!
As far as the latest version of flash. You need to get that from M/A-COM unless someone out here is gracious enough to provide it. The last code I knew of was OG45400 but there is probably something newer out now. You also need to know what flash size your Orion is (256K / 512K / 1-Meg)
Also note that there is not just an EDACS flash. All of the flash codes are EDACS capable.
