Orion VHF programming help !!
nucleaireqc
Help me, I'm trying to programming with: PROGRAMMER R18 I GET TIRED and its error message.
tank you
Thunderknight
Bletchley Park
The 2nd to last screenshot indicates you didn't create any systems in Programmer.
That's not a radio problem...that means you need to do more to your personality file before trying to write it.
Basic steps: create set with freqs, create system, assign set to system.
nucleaireqc
take control of my computer do you want? I get an error message write (Error: this is swithchable personality and cannot be programmed into this radio
Thunderknight
Bletchley Park
I believe that error indicates the radio is not capable of narrowband. (Option 23 I think, plus hardware capable of it). Is this a very early Orion?
DisasterGuy
Maryland Shore
In Programmer go to the menu option and enable the features menu. You will then be able to access features from the radio menu and see the feature codes.
nucleaireqc
I press Menu I see I actually FEATURE menu pressed again and nothing happens. One last question I believe that my CTCSS does not work as I expect the report of the tower why?
Radioman96p71
Polk County, IA
Looks like you have a 256K Radio, which won't be able to display the features from the menu.
It's been a bit but I'm pretty sure the Orions that can do NB only came in 512K boards. If you had a NB capable RF board, you would have a 150-174(sw) in the box instead of just 150-174, (sw) for switchable.
Either you can remove the systems that have narrowband frequencies in them or change all of them to wide, those are your options.
nucleaireqc
My radio is 256k with ROM6 or ROM8 ?
Radioman96p71
Polk County, IA
According to the pictures you posted "Flash Size 256K".
No idea on the tones on PTT, never messed with that before. Mine make the chirp sound on key-up on its own unless i disable alert tones.
