ORNGE in Sudbury?
sudsyjkh
Ottawa, on and Rochester, ny
Hi all. Hope you’re well.
I’m currently visiting Sudbury, and by the looks of the current Corona situation, will be here for at least a few weeks.
I’m staying extremely close to HSN (hospital) and hear multiple choppers per day coming and going, but other than a couple weather/staffing messages on 129.275, no radio coms as of yet; have been here since Monday.
I also have PCom 150.1, UHF repeater 413.6875 in my radio.
What gives?
Noticed the UHF repeater is no longer licensed to Sudbury on TAFL, which seems strange.
Thanks in advance guys.
DaveH
Ottawa, Ont.
John, you might try listening on UHF downlink frequency 418.6875, may be out of range of a ground station
but could hear some aircraft in flight.
Dave
mikewazowski
Forums Manager
Oot and Aboot
If they're dispatched from the rooftop, then I don't think you'd hear anything until they get onscene.
Might want to watch flightradar24.com or something similar. Look for LF1-7 callsigns or C-GY callsigns.
mciupa
Moderator
Huh, that's not in the DB...
On my page, they are shown. In this link, just under the blue Ministry of Health banner there is a menu for Input frequencies. Also on that line are the green square for the last 24 hour updates and the yellow square for the last 7 day updates.
You can opt for Shown or Hidden. Beside that is a Question mark that explains Inputs in the Wiki.
DaveH
Ottawa, Ont.
Well, don't most UHF repeaters use standard splits? Why would all of the input frequencies need to be listed?
Yes; and for this it is +5.000MHz although bears repeating that for UHF, 4.9875, 5.0000, 5.0125 are used,
even -11.0000MHz for 420-421MHz. Plus, OPP VR's are none of those. UHF T Band in the U.S. uses +3.0000MHz.
Quite a while back I ran across aircraft radiotelephone down-links in the 459MHz range and some planes were several
hundred km away.
Could they be using sat-phones? This was discussed several years ago.
Dave
BTW: TAFL shows frequencies licensed to some aircraft such as C-GMOH:
But note TX ERP on 418MHz is only about 5W (7dBW).
BC_Scan
Vancouver BC
hundred km away.
We used to hear that back in the day, but since cell phones those licenses that local telco provided are gone, our BC Ferries used those for pay phones on the ship , there was an aircraft system telephone that telus had @ 894 mhz rx it is also gone. the good ol days...
DaveH
Ottawa, Ont.
What gives?
BTW I would check for activity on the other VHF frequencies (paired below) listed for the aircraft, which might be in use in the
Sudbury area, if you haven't already:
149.335 (ground), 151.130 (mobile/aero)
149.710, 150.590
150.755, 151.520
plus 149.800 and 150.830
Another aircraft is C-GIMT, probably more.
Dave
ATCTech
As for MOH-related aircraft, there a bunch of PC-12s flown as "Pulse" callsign flights as well.
mikewazowski
Forums Manager
Oot and Aboot
They identify as PULxxx when airborne.
The helicopters tend to stand out on the flight radar maps. Right now I'm seeing YRPD's AIR2 and a Coast Guard chopper off of Ottawa.
ATCTech
Here's one departing CYTZ now. I believe you'll see them operating as PULSE with a patient on board and their civil registration when ferrying between locations empty.
82258
DaveH
Ottawa, Ont.
Any other aircraft registrations which could be searchable in TAFL? Other one I found is C-GIMT.
How about sat-phones...recall them being used in the "far" north...
Guess I'm just not a "plane" guy (or a "boat" guy, or "train" guy, or...)
Dave
mikewazowski
Forums Manager
Oot and Aboot
Was active a bit ago up near Timmins as PUL106.
ATCTech
This should save you using TAFL searches. Does this make me a "plane" guy or a "plain" guy? :geek:
The AW139 Rotary aircraft are:
C-GYNG
C-GYNH
C-GYNJ
C-GYNK
C-GYNL
C-GYNM
C-GYMN
C-GYMO
C-GYMP
C-GYMV
C-GYMZ
The Pilatus PC-12s (fixed wing) are:
C-GRXB
C-GRXD
C-GRXE
C-GRXH
C-GRXM
C-GRXN
C-GRXO
C-GRXR
ATCTech
RXM is southbound over Manitoulin right now using the civil reg in MODE-S. I'll watch where he goes and check the outbound to see if it's RXM or PUL ACID. That should help to confim the use of PUL only when on a patient transfer flight. (FWIW, ACID is short for 'aircraft identification' in the ATC radar data processing system.) My gut feeling (and over the shoulder of ATC time) says the MODE-S tag is arbitrary as it's not used in Canadian ATC at this point anyway. Our ATC ACID tags come from the correlating the filed flight plan against the MODE C transponder code. MODE-S (and optionally ADS-B) isn't mandatory in Canada yet.
Similar threads
