OSHP Antennas on CVPI's
CVPI4Ever
Ohio
I am not good at identifying antennas from a distance.
Anyone know what all those antennas OSHP has are for? an accompanying pic would be helpful
16b
Central Ohio
The state fair is going on right now. Last year they had a highway patrol car that you could walk right up to and see all of the antennas and radios for.
They had (if I remember correctly):
Low band
High band
Scanner
UHF PAC-RT
MARCS
MDT
CB
Maybe more.
wa8pyr
Technischer Guru
Lead Database Admin
Ohio
Low band - the big floppy one on the driver's side rear fender
High band - usually in the center of the trunk lid, bottom loaded, ~3ft whip
Scanner - antenna on the right or left side of the trunk, may have 2 center loading coils
UHF PAC-RT - small antenna usually mounted on the light bar
MARCS - 800 MHz pigtail antenna on the roof
MDT - 800 MHz pigtail antenna on the roof
CB - CB antenna on the left or right side of the trunk
Tom WA8PYR
FPO703
Planet Earth
What about one in the center rear of the roof that looks to be about 1 inch high and about 3-4 inches around? AVL? GPS?
bigbluemsp
Michigan
Could be 800mhz antenna. Its a different manufactor of antennas. Antennex......
mdulrich
Van Wert, Ohio
That would be the GPS antenna.
Mike
mdulrich
Van Wert, Ohio
I'm seeing quite a few using a 1/4 wave for one of the 800 MHz antennas (pigtail for the other) here in NW Ohio.
Mike
FPO703
Planet Earth
If I could get away with taking a photo of the tail end of one of the Post 4 (Ashtabula County Post) without being shot at by one of these guys, I'd try to get a close up for you all to look at.
CVPI4Ever
Ohio
Why would you "get shot"? You have every right to look at it. Just ask first.
acegta2002
First attempt at this so I hope it works. Older picture of cruier and I can't remember where it came from.
acegta2002
Sorry forgot to label them: Left to right: Low band. On the trunk: scanner, C.B., scanner,extended range antenna for the mobile video mic. AM/FM antenna on right rear. What I see missing is the usual VHF high band usually located on the left or right fender. On Roof: 800 for radio, center rear GPS, then the 800 for mobile commputer. Attached to the light bar the uhf MRE antenna.
SLWilson
Ohio
OSP Car antennas....
CVPI4Ever said:
I am not good at identifying antennas from a distance. Anyone know what all those antennas OSHP has are for? an accompanying pic would be helpful
These help any? Side view of AM/FM antenna, CB, Low Band, Hi Band, In Car camera audio antenna, all on the trunk lid - Rooftop is GPS and MARCS mobile antenna....A couple (passenger side & driver's side view of the interior, MDT's radio equipment and a shot of the stuff crammed into the trunk to make it all go!!!! See below......
SLWilson
Ohio
OSP Cars
CVPI4Ever said:
Steve, thats the pic I was looking for. Thanks!
That was just about all the angles I could get. Hope that helps. One of the guys stopped by the office after he got his MDT & we "took a tour" of his car!!!!! Steve/Gallia :)
2112
OK
shaft said:
Nice pics, sad to see the cruisers in the plain white. I miss the charcoal grey with the gold 3m striping.
Me, too. Those white cruisers have to be a pain to keep clean in the winter...
