OTAP and MotoTRBO 2.10 Radio Management
mark-fwi
Lincoln, NE
Has anyone accomplished over-the-air-programming with the new 2.10 firmware and 2.18.95 Radio Management version in MotoTRBO radios? I have tried multiple PCs and RM servers and am not able to succeed when using the repeater NAI data interface and MNIS. I am able to ping the radios and the Device Monitor software sees that there is a job but it fails with Error Code: 463 [ Application has encountered an error. The connection to the device cannot be established. ]
Motorola tech support hasn't been any help.
N1GTL
CT
I too have used WiFi, not OTAP and had to occasionally go into services and manually stop and restart the RM server.
Firebuff880
Boynton Beach, FL
@mark-fwi
Did you update DDMS & MNIS ? Did you get a clean connection test from DP and ensure that only OTAP is selected ?
In MNIS change to Logging Level 3, create a report and then look at to make sure your repeaters are talking with MNIS.
Can you ping the subscriber from the MNIS / DP box . 7002 = 12.0.27.90 or what ever your subscriber is -
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I have done a good bit of otap on the newest CPS on both cap max and cap plus. I am with Firebuff on the MNIS or something not correct in DP. TT
mark-fwi
Lincoln, NE
Motorola came through and fixed this issue. They sent me a new TransportLayer.dll file for use on the OTAP device programmer PCs to get me up and going. They admitted there is a bug and it will be fixed in the next release in late summer 2019.
We have over 4000 radios in our company RM server, with that many radios there are multiple OTAP keys in use. Since we have multiple OTAP keys on the RM server the DP won't work without this new .dll file.
MNIS and DP were setup perfectly and running the latest versions.
JMLW33
You have to make the connection between the PC and control station by Bluetooth better than USB coz of IP conflict and turn on a Wireshark to Monitor the operation.
mark-fwi
Lincoln, NE
I am not using a control station. I purchased the wireline data gateway license for each repeater in the system so now I can talk to the repeater via MNIS. No need for control stations for each TG in a capacity plus system when using the wireline data license.
JMLW33
That's really good coz of the problems we face using control stations. I tried one day doing OTAP using MNIS and DDMS (PN server) but wasn't successful. So what wireline data is ???
As long as you're using a capacity plus system. I'm trying now to configure a capacity plus in two dispersed sites, one repeater in each. what are the requirements? How many TGs can I do and how many channels in the zone and in the channel pool can I do?
Your help is appreciated
JMLW33
If you mean NAI (Network Application Interface), you have to be connected to the repeater by Ethernet cable and not remotely
