SOUTH300
Greetings,
I have been at this for weeks, and finally need a hand getting this up and running. I am attempting OTAP using a single conventional repeater channel. My control station radio is a XPR3500 connected to my host PC using the original programming cable. The PC I am using is a clean install Windows PC running Windows 10, loaded with Radio Management, DDMS, Device Programmer, RM Job Processor, and RM Server Utility. I believe I have the parameters set correctly in the Control Station radio. I have it loaded using Radio ID 100. Under Control Station, I have Forward to PC selected. The test radio is an XPR7550e. Both radios can talk to each other on the selected voice channel, and I can call alert and radio check each radio back and forth. I have Data Call Confirmed checked on both radios. ARS is set on the 7550e to On system change. ID 100 is set for the ARS ID in the 7550e.
I can see the 7550e trying to register, and the control station signal strength meter comes on. Both show full strength, as I am well in range of the repeater. Sometimes (50%) of the time, the high speed data Icon comes on on both radios when the radios attempt to exchange data. I can ping the control station every time from the host PC. I can only ping the test radio about 10% of the time, from the host PC. The channel that I use, uses Basic Privacy. Device Monitor never sees the radio turn on. Radio management just hangs at Waiting for Device. On the PC, I have set a persistant route between 12.0.0.0 and 192.168.10.1. I have opened all ports on Windows Firewall.
In the settings on Device monitor, the RM Server and PN Server both report successful connections. USB and OTA is checked. I have also tried to use a simplex channel to rule out any interference or signal issues with no luck.
Any guidance or assistance would be greatly appreciated to get this working.
Thanks!
Thanks!
