slicerwizard
Due to my limited battery life on my laptop using it is not feasible until I replace the battery.
Can you pm me or point me in a direction of some instructions for to see the LCN?
One other concern is I was seeing when locked onto the second Frequency TGs that were not in the pattern of 11, 21, 31 etc and were in another language it was too brief to identify. Might it be a shared frequency within range of the airport with another system?
Frank
Thanks for the tip. Its a cheaper option that is for sure.
The system I had in the unit was the following based on what I thought was the same system. Looks like we are looking at two separate systems at the airport.
CYOW Air Canada
Site 01 Parkade Roof
DMR One Frequency
460.700000 CC=8
Now both are ready to go and I will be in and around CYOW this morning.
Frank
1 Airport Authority System
463.0125 Cap+ DCC=1
TG 31
TG 71 - Interior Security/Air side security
2 Airport Ops of some kind
TG 231
461.4125 DMR DCC=2
Which frequency is this logged from? Hopefully not more than one, that will add Confusion (**).
Right now I see TGs: 1, 11, 41, 51, 71 and 81 on 463.0125, with various RIDs. There is more, this frequency is particularly
messy. I also get Nexedge 9.6k RAN=2, and more. People will hear different mix depending on location.
TG 1 has CC=1, part of another Cap+ system.
Solution to the Airport system is not complex: two frequencies with same Colour Code. One frequency has Ch 1 and Ch 2,
other has Ch 3 and Ch 4. Everything which does not fit the pattern e.g. TG 1002 is something else.
461.4125 seems to only have users for Airport system, can be used to screen the users seen on 463.0125.
Dave
** sounds like a song by Little Boots!
Dave,Hi Frank,
Minor picky point, you are referring to TGs as "tags". Tag is text associated with a specific TG. You can have the
same TG number used on different systems, with different tags. Example: TG 31 used on this system and the CU
system (and others) but they have no connection to each other.
Unfortunately DSD+ does not show the CC's in event file, or the frequency at the time. Sometimes you need to
be watching DSD+ windows in real time.
Dave
Air Canada is not a Cap+ system, it is a set of conventional repeaters. If it were Cap+ you would find a "rest channel"I went back to the airport this afternoon and put the following together.
For the
Air Canada System Cap+
460.70000 CC=8
461.63875 CC=8
462.42500 CC=8
TG=1000 Air Canada Baggage Handling Ops
TG=1001
TG=1002 Ground Issues
Slot 1 has been seen.
This was programmed in the 436HP and sounds like everything is close to perfect. Maybe its missing a frequency but that's what I have.
For the
460.70000 CC=8
461.63875 CC=8
462.42500 CC=8
TG=1001
