DaveH
Software showed Cap+ so that is why I included that. If something makes it not software is making assumptions am I correct? I also logged Airport Authority tags on that frequency which is why I included it as part of the "system." Thanks again for the feedback.
The Air Canada frequencies are not Cap+. Possible explanation is in DSD+ Event window if
you were monitoring a Cap+ system then switch frequencies to conventional, the Cap+ may
still be displayed at the bottom; check that. If in doubt, clear the system line, may need to
exit/restart DSD+.
If you are seeing Airport TGs 11, 21....etc on the Air Canada frequencies that is interesting but
also worth checking, using RIDs. Airport radios might be able to operate on Air Canada frequencies
but does not mean they are the same system.
As mentioned earlier, TG numbers can be the same in different systems but be unrelated. In my
logs I find several TG 1000's etc. on different systems.
Dave
