Outdoor Antenna for BCD996P2
Tomlbra
Peoria Arizona
Purchased a BCD996P2 and looking for recommendations for an outside antenna to mount that receives trunk and digital. Thank you.
iMONITOR
Silent Key
S.E. Michigan
CT
While there's no such thing as an antenna that receives exclusively "Trunk and Digital" (A Radio signal is a radio signal) , a "Discone" antenna receives a broad range of frequencies.
The antenna you choose should be designed to receive the frequencies you intend to monitor.
You can find Discones at just about any place that sells antennas.
Tomlbra
Peoria Arizona
Thank you for the fast replies. Most of Maricopa County is in the 120-155mhz and 700-900mhz ranges., With state in the 460mhz range. With it being that wide of a range, a Discone seems like it would give the best coverage.
iMONITOR
Silent Key
S.E. Michigan
The discone does not perform great for 700-900MHz. That band is where the Omni-X will probably perform better.
Bob1955
Eastchester, NY
Your BEST bet is Diamond. Contact The Antenna Farm--just look them up in GA or Amazon.com and just search out the ratings, sir.
Stay safe.
