That should work fine for scanning the CB frequencies on your scanner, but probably won't work too well on the higher frequencies used by many of what you'll probably want to listen to on your scanner. For that you'll need an antenna designed for those frequencies instead. Check the RR database (using the Databases button above) to see what frequencies the agencies you want to hear are using. If they're above 40 or 50 MHz, that antenna won't do you much good, I'm afraid and you'll need to get an antenna that's designed to cover where you want to listen.
