Outdoor Directional Yagi Results For Detroit PD/FD, Anyone?
wbruff
Southeastern Michigan
I work for a local TV News station in Southfield and have installed a set of stacked yagi antennas. We can hear the control channel(868.725 Mhz) clearly but unfortunately still choppy audio on the broadcasts. I'd venture to guess that the signal level is probably not the issue here.
toydriver_det
Madison Heights
I bet you can pick up a FRS radio in downtown Detroit with that setup!
jjr0062
Rochester Hills
I too tried the Yagi antenna. Got 95 - 100 on the display but still choppy here in Troy.
Jim Richards
w8jjr
feta92
St. Clair Shores, MI
The thing is is that you are receiving Det in Troy with an outdoor ant. but not with the stock rubber duckey correct?
KB8UYC
Ypsilanti Michigan
Guys,
I have done some talking and the problem is the modulation scheme. it is a different type, and the scanners cannot decode it properly. We will have to wait for Uniden and Radio shack to come out with upgrades. I too have a 7 element yagi with 10db and still cannot monitor it from ypsilanti.....
mrhowes
Twin Cities, MN
And I think you will not get great reception from Ypsi. I mean we are talking about being 40 or so miles away. That is a long distance to get Detroit's system.
Here in the Twin cities, if you are more than 10-15 miles from the nearest tower for a given system, you are rarely going to get a good signal, even with an outside antenna.
Food for thought.
seamusg
Grand Blanc, MI
Food for thought.
were talking about 1 mile- one person is in Harper Woods.
Ya know with all this in mind....(the problems with the detroit system) I hope there isnt problems with future subsytems throughout the state. (i.e. the soon to go online macomb subsystem)
rdale
Lansing, MI
"Ya know with all this in mind....(the problems with the detroit system) I hope there isnt problems with future subsytems throughout the state"
Since it's been an issue with Monroe Co subsystem and possibly the Genesee Co subsystem, I find it hard to believe it'll be different for any others until (unless) the scanner makers come up with an update.
"(i.e. the soon to go online macomb subsystem)"
The MPSCS page here says it won't start transitioning until late 2006 so I think you've got some time ;>
EC-7
Saginaw Co. Michigan
I used to know someone who had a 102" CB whip under a bed cover. They basicly mounted it sideways, in a "U" shape, with the feed point and tip both on the drivers side of the bed, and the center of it tied with string to the passengers side to hold it up. It was horizontal, and I'm not sure how good it worked, but I think he used it mainly for RX.
You could try to just mount it in the center of the bed, and make a upside-down "U", running it front to back, and maybe get dectent signal.
KB8UYC
Ypsilanti Michigan
Food for thought.
Well for starters you would be incorrect. I recieve the Detroit system from ypsilanti at about 95% decode rate, it does bounce around and it does it 0% quite often. I have no problems with it other than I cannot hear it clearly due to the choppyness of the modulation scheme.
