Over the air programing (OTAP) and XPR6550?
DuneDevil
Kingman, AZ
I've got about 100 radios to program and my managers keep wanting "tweaks" to how the channels are organized.
I see in the system planner doc that OTAP would be very helpful in my situation, but I'm having trouble installing it (windows service isn't running).
I called Motorola and they said that the XPR6000 series doesn't support OTAP anyway... Is that true?
VE3RADIO
Planet Earth
If you asked Motorola and they told you an answer why would you come here and ask.. just curious?
DuneDevil
Kingman, AZ
I ask here because:
1. There are other members who have extensive experience administering a fleet of XPR6000 series radios.
2. While I value Motorola tech support, I don't know the experience level of the individual I spoke with.
3. Just because something isn't officially supported by the manufacturer does not mean that it isn't possible.
N4KVE
PALM BEACH, FLORIDA
If you call Moto to ask them if a XPR6580 will work on 902/927 ham freq's they will tell you "no". But as we all know with a little hex editing, it works on 902/927 just fine.
KG4INW
Midlothian, VA
As an MSS employee who's worked on both generations of TRBO radios, they are correct. The 6000/4000 series do not support OTAP, only the newer models (7550, 5550, etc).
EncryptedTech
They are correct that series will not do OTAP, don't worry its so slow, its faster to drive around to them all.
DuneDevil
Kingman, AZ
Thanks for the confirmations, I was afraid of this. Well I guess I need to figure out a way to migrate to the XPR7550s... :)
Thanks again.
vans113
Tennessee
You would never want to use that anyways for 100 radios it is EXTREMELY slow
Sent from my iPhone5 using Tapatalk
DuneDevil
Kingman, AZ
Interesting about the slow speed. I'm thinking about migrating to the 7550s, one of the main reasons being the OTAP. Can't you just set up batch jobs and let the system take care of it over the course of a few hours?
I'm sort of "thread-jacking" my own thread, but OTAP isn't all it's cracked up to be?
Firebuff880
Boynton Beach, FL
Yes, that is exactly what you do -- You need to install the Radio Manager that comes with CPS to do this, and while it's not required, the Wireline data interface (MNIS/DDMS) is recommended over the Control Station approach, but both work.
