Overland Park Kansas
Kansas City Missouri
I programmed the frequencies from this site for Overland Park Ks. and I am not hearing anything. I am sure I put them in right. Anyone out there that has the frequencies and talk group id's could you pass them my way so I could make sure. Thanks.
KCMO
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Mark, if your scanner is GRE, make sure you start the freqs in channel 1 through 5. Use a conventional freq in channel 0 or lock it out.
I scan OP both directions traveling through on I-435 and it works well for me. I might add, those are the same TG's in my Win92/95/96 and ARC785 software.
jcecklund
Kansas City
Overland Park
Mark,
Overland Park does not talk much on the radio, They are using Laptop computers to make and receive calls. You can't monitor the Laptops they are all encypted.
Once in awhile you will hear them talking on the radio.
JC
I dont know if my scanner is GRE or not. To be honest with you I dont even know what GRE means. :? I just bought a new Uniden BC246T.And the fact that they use laptops really sucks if you ask me. Thanks to both of you for the information.
KCMO
jcecklund
Kansas City
GRE
Mark,
GRE is a scanner manufacturer that makes scanners for Radio shack and other companies.
I turned on the Overland Park bank trunked system and I am hearing them talking. I don't normally hear them much but today they seem to be talking more freely.
The Bearcat 246T is a very good scanner. If you are fairly far from Overland Park you might not be able to pull the signal in with your stock antenna. I would suggest getting an 800mhz antenna for your scanner. Your trunking agenices will come in much better.
JC
jcecklund
Kansas City
Overland Park Talk group ID'S
17 00-021 SANDERS
18 00-022 INFO
19 00-023 INFO-2
20 00-024 TLK-ARND
21 00-025 INTER-CO
22 00-026 SIS-1
23 00-027 TAC-1
24 00-030 TAC-2
25 00-031 OPFD
26 00-032 CTY-WIDE
27 00-033 EP
28 00-034 OP-M-AID
29 00-035 SIS-2
30 00-036 ADMIN
31 00-037 ERICSSON
33 00-041 ERICSSON
