Hello,
New member here but have used database extensively.
I work for a company that uses UHF LTR port/mobiles for our comms. It is a statewide system. Here is a map of it
http://www.marcusradio.com/images/coverage_map_voicelink_lg.gif
I have found this as well. A list of freqs used. There are two links.
http://www.radioreference.com/apps/db/?sid=4117
http://ecscanning.com/viewtopic.php?f=30&t=1348
I am looking at buying the BC246T. I would like to monitor my company using the scanner but I seem to be overwhelmed with the trunking system.
When I am at work, turn the truck on the radio comes on and it displays "searching", then the antenna meter comes on with a # ranging from about as low as 40 to 110. Then the display says "registering", then "connected XXXX" (XXXX being what I am assuming is the site - New Haven, etc..), then it shows "ASID#XXX" after that the display shows the channel name and we are able to use the radio. Total time to do all this is about 10 seconds to 60 seconds.
We have 3 "channels"( i think called talkgroups in trunking)
Now the questions.
How do I go about programming the scanner? Seems to be Alot of frequencies to put into the scanner.
Since we have 3 "Channels" I would only need to find the ID's for those specific "channles"? Anyone in the company who uses the radio I would then be able to hear. Correct?
Just really overwhelmed as to where to start.
Thank you
firebuff17
Now the questions.
Thank you
firebuff17
