The SID:0140h-0337 is System ID 0140 (Starcom 21) and Site 03-37 (Cave In Rock).
Looks like you're in a spot for "overlap" of these two systems being in Morganfield.
Based on my monitoring and background of that area, I'm inclined to believe you're more likely to receive the Starcom21 system than Owensboro's system - just due to distance. The Owensboro system is quite a long-haul away from Morganfield in terms of radio reception, including terrain.
I'm also guessing you have all of Owensboro's frequencies programmed in your scanner - you only need to program the Control Channel frequencies in order to properly receive the system (the red/blue ones with an "a" or "c" beside them). See below and remove the non-control channel frequencies.
By having all of the frequencies programmed in, your scanner is locking onto the strongest control channel signal and that is why you are receiving Starcom21 instead.
Program in only these if you want to hear Owensboro:
853.8375c
852.6250a
853.0875a
853.5750a
If you are wanting to hear Starcom21 off the Cave-In-Rock tower, program in these:
852.3125c
852.8375a
This should eliminate the situation.
