P-25 Wacn
JerryNone
Ohio
Is this some type of radio ID or something else?
Does anybody know what WACN means? I take it that it is an anbreviation of some sort.
Thanks.
Hi Jerry;
Wide Area Communications Network.
In P25, the System ID identifies the system. One or more systems may be joined into a network of systems. The WACN identifies the network.
-rick
greenthumb
Colorado DB Administrator
Mike_Oxlong said:
It would be comparable to an ID given to an Omnilink system.
But do keep in mind that in an OmniLink P-25 system, the WACN and system ID are the same across zones.
