P/M 7200 Questions
DisasterGuy
Maryland Shore
What is the model of radio. We have seen some of our newest radios that are featured for both EDACS and P25 not actually show EDACS in the feature menu even though it is there. Perhaps there could be a simular issue with yours.
Sent from my SM-G900V using Tapatalk
TDR-94
I've also been told that P25T needs to be enabled in any radio for Phase2 to work,in the same way P25C is required to be enabled with P25T.
ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
DO NOT ASK ME FOR HELP PROGRAMMING YOUR RADIO. NO.
M5300. I had it in my last car but haven't figured out a satisfactory way (yet) to hide the front control head in the car so that it's accessible but not visible so it's currently in a box waiting for me to solve that problem.
I know that the P25 phase 1 trunking option is something like 1100 dollars. Which is just retarded.
I'm also curious as to whether or not the M5300 needs hardware added to it to enable the GPS functionality. Or if it's just a feature upgrade only.
DisasterGuy
Maryland Shore
I'm pretty sure the 5300 requires a board for GPS. If it has the board there will be an SMA connector for the GPS antenna.
Radioman96p71
If you have the SMA connector then you have GPS. It's not used for anything but OpenSky but you can tap into the NMEA stream from the accessory connector.
