I'm wanting to start checking the programming of all the P1225's we have. Not sure how many, if any, are actually set for narrowband.
Years ago, we could program these radios, but someone pitched the computer I used to do it on, and I can't seem to get the software running on the newer machines at work. I have not programmed one in years, because of this.
Here's a list of everything I'm working with:
The software is HVN9054D Version 3.2
The computer it's installed on is running Windows 2000 Version 5.0. (Build 2195:Service Pack 3).
This computer is not on the internet, it would be possible to do a Windows update if someone thinks it may help.
Both the radios I tried this week are model P94ZRC90C2AA.
The programmer is HLN9359A, The RIB box is RLN4008B.
All hardware is genuine Motorola.
The error I get is:
Error: Radio is not active
Check the following:
1 ) Connection from the RIB box to the radio.
2 ) Power supply for the radio.
3 ) Is the radio on?
The radio battery is new. The radio is on. The battery in the RIB box is new. The RIB box is turned on.
I've tried to select all four comports. Port 1 and 2 give me the above error message. Port 3 and 4 just say "you don't have this port".
I can program GP300's and CDM1250's just fine thru the same cable and RIB box.
If it's a version issue, I'll buy new software, I just want to make sure it works on the computer I got before I buy it. I'd kinda like to get it to work on the machine described above, since that's where the rest of my programming software is.
Any ideas are greatly appreciated.
The error I get is:
